楼主: luotianze
TP行业新人不可不了解的知识
发表于 2014-10-28 09:12:27 | 显示全部楼层
谢谢分享资料,学习了
发表于 2014-10-28 09:14:05 | 显示全部楼层
* ?4 j+ C8 J( x/ \6 d% R' x( A謝謝您的無私分享!
发表于 2014-10-28 11:27:27 | 显示全部楼层
我想下载,多多回帖子了;
发表于 2014-10-28 11:28:44 | 显示全部楼层
金币不够,再回复个下载
发表于 2014-10-28 11:51:20 | 显示全部楼层
顶你  下载看看
发表于 2014-10-28 13:27:17 | 显示全部楼层
Chip-Level DC Specifications) u$ P% v# ]* {+ ^3 E( N
The specifications in Table 8 are valid under these conditions: –40 °C  TA  85 °C, 1.71 V  VDDD  5.5 V, 1.71 V  VCCD  1.95 V,2 s. w# d4 d4 ?- `1 u: Q/ Q
and 2.65 V  VDDA  5.5 V. Typical values are specified at TA = 25 °C, VDDD = VCCD = 1.8 V, core LDO disabled, and VDDA = 3.3 V.8 ?7 s! k3 ^0 p- k9 g. [  C4 r$ N
I/O Port 0 (P0[0:1]) DC Specifications
# g+ ~9 Y# i) z+ A" g$ `8 NThe Port 0 specifications in Table 9 are valid under these conditions: –40 °C  TA  85 °C, 1.71 V  VDDD  5.5 V,2 B5 B6 ?+ n: W% I" t0 S- e8 ?
1.71 V  VCCD  1.95 V, and 2.65 V  VDDA 5.5 V. Typical values are specified at TA = 25 °C, VDDD = VCCD = 1.8 V, core LDO
; E5 V8 B  I: @5 C6 Xdisabled, and VDDA = 3.3 V.) y$ t% ?: Y) d
Table 7. Flash Specifications5 S; K6 }) z8 v+ d% _/ D7 W7 t2 e
Symbol Description Conditions Min Typ Max Units: _& c& {$ j1 C- o. y
FlashENPB Flash write endurance Erase/write cycles per block 10,000 – – cycles1 x/ Q) k$ z! q
FlashDR Flash data retention Following maximum Flash write: H5 f5 L0 R) A7 P) {4 ~! U
cycles (FlashENPB), TA  55 °C
3 M( Q2 v& E% h0 K" \20[16] – – years+ M; x3 e% E" o5 |- |0 T9 H  T8 N
Following maximum Flash write8 n  u& @& j) E% Q: S9 u# O
cycles (FlashENPB), TA  85 °C
! g, u! b. U8 n% \10[16] – – years
. U8 d8 j# C3 S2 b7 H0 GTable 8. Chip-Level DC Specifications
) L) p; Y; }, T3 J, zSymbol Description Conditions Min Typ Max Units
2 [4 u  O2 [, o+ gVDDD Digital supply voltage Core LDO enabled (VCCD output) 1.8 – 5.5 V
, M, E+ W) Y: K4 d' U( nCore LDO disabled (VCCD input) 1.71[17] – 1.95[17] V' k  h4 A, z1 J$ p1 Z! O
VCCD Digital core supply voltage Core LDO enabled (VCCD output) – 1.8 – V
! M! t3 z# W6 P/ K- PCore LDO disabled (VCCD input) 1.71[17] – 1.95[17] V" @/ R7 c, `1 B# I4 `7 l
VDDA Analog supply voltage 2.65[17] – 5.5 V
& a; m" J6 R6 c( D+ KIDDD_ACT VDDD active current – 10 50 mA
0 B/ e* P' w7 _6 M  P! G' A& n, K5 QIDDA_ACT VDDA active current TX pump enabled – 9 12 mA
9 X. Z8 t  @, P3 g9 X8 rIDDD_DS VDDD deep sleep current – 1 – μA
. B  o/ _) g+ Y  cIDDA_DS VDDA deep sleep current – 1 – μA
/ \( i+ A5 h* sIDDD_P VDDD flash programming and flash! _) N" O7 v. m% D
verify current3 V0 ?) F- ]* O2 j3 X. j; J
– 5 25 mA
发表于 2014-10-28 14:10:08 | 显示全部楼层
好東西阿,先弄点金幣来。
发表于 2014-10-28 14:14:27 | 显示全部楼层
金幣QQQQ没金幣怎麼拿資料
发表于 2014-10-28 17:34:28 | 显示全部楼层
好帖子好帖子好帖子好帖子好帖子好帖子好帖子
